Door pins and bushings
z71steve
Hey guys has anyone done hinge pins and bushings in a 2000? Never done it before and trying to figure out the best way any input helps
Sent from my LGLS676 using Tapatalk
andyvillen
sudbury,on
They are pretty easy actually. There is 2 10mm bolts on the door hinge. Take them out, unplug the door jamb wire from behind the lower kick plate and the door lifts right off. The pins have snap rings holding them on if I remember correctly
Untamed
Winnipeg
Might as well revive this one year at a time. :D
This explanation sounds like after market door pins. The factory door pins need to be ground or cut off.
https://www.youtube.com/watch?v=g7-j1KYzYH8
... for further reference.
