Chaingun427
Looking for some direction with an error message in getting
Truck is an 04 tahoe
6.2 bored lq4
4l80e swapped ( guessing 2300-2500 stall, trans and converter were used)
Long tubes, baby summit cam, other minor mods
Derale 28k cooler
And cluster swapped from an 03 escalade
My issue lies somewhere between the transmission, pcm, and cluster, but I'm not sure exactly where.
Any time the trans temp exceeds 150 degrees, the cluster will randomly trigger a "transmission hot" message, even though scan data confirms the hottest reported temp to be 180 degrees. Transmission hot mode in the tune is set to 266 degrees, and no dtc or change in shift modes are present when the message pops up, and flow through the cooler is fine.
I'm unsure what parameters are causing the transmission hot message in the DIC without triggering the hot mode in the tune.
Could it be that the cluster came from a vehicle only ever equipped with a 4l60e/65e?
I do have info on how to download the cluster binary and edit it, though i haven't had time to do so yet.
6.2 bored lq4
Derale 28k cooler
