ABS issue
kjamesm
washington
Hey guys so i have a 2004 Silverado 1500 with 118k on it. The engine light was on throwing codes for misfired and the ABS light was on. Had a shop read the codes and the ABS was a "rough road sensor" and i was told it was most likely caused by the misfiring which was very bad. I took the heads off and fixed the issue with the misfiring, truck runs super smooth now (was a valve with a messed up seat from carbon build up) but the ABS light is still on. The light is not just on the pedal flutters to the floor when turning right and going fairly slow (between 5 and 15mph), i haven't had the codes checked to see if its still the rough road code or if its changed but i was hoping to troubleshoot it myself. Anyone have any idea what would cause the light to be on, the pedal flutter to the floor when turning right but throw a rough road code? The light comes on as soon as the truck is started but goes off sometimes when on the freeway.
