35" tires with leveling kit
Auegl
Would 35x12.5 tires on a 17" rim that is 10" wide fit under '06 sierra 1500 extended cab with 3 inch keys in the front and 2 inch blocks in the rear? Any help is appreciated. Thanks.
Auegl
I was afraid of that. Ok. If I want 35s on a 10 inch rim, what do I need lift-wise to clear with minimal trimming?
02Beast
Duncanville, Alabama
This is what mine looks I have 20x10's -24 offset 35x12.50r20 a 6" ntd lift stock keys that are 4 threads away from being maxxed
[/URL][/IMG]
Auegl
Ok. Now, if I stay with something close to stock width, will I be able to use the 3" keys? I don't have the money for that big a lift at the present.
02Beast
Keep in mind with keys you need an alignment because your changing geometry also need new shocks or extenders, make sure the keys are Ford 97-03 keys or aftermarket keys that are forged make sure they are forged
962000chevy
After comparing a set of 315/75r16s vs my current 285/75r16 I think they'll fit easily maybe so trimming but nothing too major.
Z -56 Hoe
A 4" CST spindle lift and pro comp level lift kit and we cleared 35X12-50R20s BTW the aftermarket keys are not cranked. 20140515_183201.jpg
IMAG2566.jpgthe last photo is before the lift
